Activity Forums Adobe After Effects Expressions scripting: add a custom default layer in Layer Control?
  • scripting: add a custom default layer in Layer Control?
    Posted by Santi Agustí on May 27, 2016 at 2:22 am
    Hi! I recently purchased the awesome ft-toolbar, so I decided to finally (try to) create a little script for the automation of the cam + nulls creation I aaalways do o every project (and add it as a button to the ft-toolbar)
    When I add a Layer Control on the null (to pick the Layer wich will be the focus target for the DOF control), is there a way to start with a given layer from the beginning, or that is not possible?
    I have this, inside a null:
    var focuslayer = camNull("Effects").addProperty("Layer Control");
    focuslayer.name = 'focus layer'
    so I tried to simply add the focus layer (a previously created null called DOF) like adding a value, but I guess it’s not the correct way
    focuslayer.property("Layer").setValue("DOF");
    do you think it’s doable?
    thanks in advance!
    Santi Agustí replied 10 years, 3 months ago 2 Members · 2 Replies
  • Xavier Gomez
    May 27, 2016 at 7:20 am
    The argument to setValue should be the index of the layer (or 0 for ‘None’):
    focuslayer.property("Layer").setValue(doflayer.index);
    Xavier
  • Santi Agustí
    May 27, 2016 at 11:28 am
    Thanks Xavier!
    worked perfectly!
