Activity Forums Adobe After Effects Scriptied GUI listbox scrolling bug
  • Scriptied GUI listbox scrolling bug
    Posted by Gabriel Valkama on September 10, 2014 at 1:56 pm
    Hi!
    I need to use a listbox with hundreds of rows. The thing is, it seems that I loose the listbox scrolling ability if I try to confine the listbox to a reasonable size. Here is a sample:
    var FSWindow = new Window("palette","Listbox Scroll Bug", undefined);
    var FSList = FSWindow.add("listbox", [0,0,500,205], "FS List", {multiselect:true, numberOfColumns: 2, showHeaders: true, columnTitles: ["First","Second"]});
    for (i=0;i<50;i++)
    var curItem = FSList.add ('item', "Row"+String(i)); // Column 1
    curItem.subItems[0].text = "Row"+String(i); // Column 2
    FSWindow.center();
    FSWindow.show();
    There are 50 rows in the listbox but you can only access the first eleven of them.
    I have tried searching google and Javascript Tools Guide CS6.
    Thanks in advance!
    Gabriel Valkama replied 12 years ago 51,109 Members · 2 Replies
  • Gabriel Valkama
    September 11, 2014 at 5:10 am
    Scrolling seems to work when using ‘ExtendScript Toolkit CS6’ as the target application. When changing to ‘Adobe After Effects CS6 (11.0)’ scrolling breaks.
  • Gabriel Valkama
    September 11, 2014 at 5:40 am
    Just had to create the window before populating the listbox:
    var FSList = FSWindow.add("listbox", [0,0,200,205], "FS List", {multiselect:true, numberOfColumns: 2, showHeaders: true, columnTitles: ["First","Second"]});
    FSWindow.center();
    FSWindow.show();
    for (i=0;i<50;i++)
