Activity › Forums › Adobe After Effects Expressions › Scripted animation triggered by the comp marker
  • Scripted animation triggered by the comp marker
    Posted by Chadi Nassrallah on September 5, 2015 at 12:37 pm
    Hello guys,
    I’m new into expressions, and I would like to write an expression that combines two expression into one.
    I’m using this expression to animate the position easeOut(t, 0, 1, [x,y], [x1,y1]), but I want to trigger this animation to start by passing by comp marker with a comment Start and then invert my animation by a comp marker comment end.
    Why I’m using this expression easeOut(t, 0, 1, [x,y], [x1,y1]) because I need to link the [x,y] to a null position so I will be able to control my starting position manually.
    Thank you for your help
    Chadi
    Chadi Nassrallah replied 11 years ago 3 Members · 2 Replies
  • Miguel De mendoza
    September 7, 2015 at 4:29 pm
    Start here: https://motionscript.com/design-guide/marker-sync.html. If you want to use interpolation functions many times, check this: https://forums.creativecow.net/thread/227/30494.
    If you only want to make one linear on one property controlled by markers you can write this:
    t1 = marker.key(1).time; // If the marker is on other layer : comp("xxx").layer("xxx").marker....
    t2 = marker.key(2).time;
    startPoint = [x, y];
    endPoint = [x1, y1];
    linear(time, t1, t2, startPoint, endPoint );
  • Chadi Nassrallah
    September 19, 2015 at 12:07 pm
    Thank you for your help,
    The expression works fine but i’m still trying to figure out how to use the interpolation many times. i checked the links you sent me but its quit advance to my expression experience.
    What i’m trying to achieve is applying this interpolation expression to position property of a layer to move from position1 to position2 triggered by Marker1 till Marker2 and hold till marker3 to move from position2 to position3 until marker4.
