Activity Forums Adobe After Effects Script works fine as solo composition, but syntax error when imported to project
  • Script works fine as solo composition, but syntax error when imported to project
    Posted by Lee Pines on October 15, 2020 at 3:32 pm
    I have this script that I’m using to control the color of multiple shapes in one composition. It’s connected to a slider, so I can use the slider to change a set of predetermined colors of all shapes that should be that color.
    So, for example, I have a bunch of text on a colored background and I want to use the slider to change the color of all the background shapes.
    This is my expression for the slider:
    slider = Math.round(thisComp.layer(“Color”).effect(“Slider Control”)(“Slider”));
    which is followed by this for each color:
    colorValue1 = thisComp.layer(“Color”).effect(“Color Control”)(“Color”);
    if(slider==1){colorValue1};
    It works beautifully in a solo composition, BUT when I import this composition into another, I get the following error on the first line:
    Error: Undefined value used in expression (could be an out of range array subscript?)
    Does anyone know why this error happens?
    Lee Pines replied 5 years, 11 months ago 2 Members · 7 Replies
  • 7 Replies
  • Brendon Murphy
    October 15, 2020 at 4:47 pm
    Is there more than one layer with the name “Color” in your new comp?
  • Lee Pines
    October 15, 2020 at 4:50 pm
    No, I keep it in the composition and drop the composition into a new comp. It’s weird, there’s nothing else in the whole project with the same name
  • Brendon Murphy
    October 15, 2020 at 5:23 pm
    Oh – I wonder if “thisComp” starts referencing the parent comp. Try calling the comp more specifically, by name.
  • Lee Pines
    October 15, 2020 at 5:24 pm
    Thanks! How would I do that?
  • Brendon Murphy
    October 15, 2020 at 7:29 pm
    I honestly can’t duplicate your problem. You are using this setup in say, “Comp 1”. When you place the entire Comp 1 into Comp 2, the expression in Comp 1 breaks? Is it just when you are in Comp 2?
    You can try using: comp(“your comp name here”)
    instead of thisComp.
  • Lee Pines
    October 16, 2020 at 8:57 am
    Thanks for the help. I tried the comp name script you suggested, but the same error comes up. What happens is: if I open the project alone, the script works. But, if I import the project into another project, the script breaks
  • Lee Pines
    October 16, 2020 at 9:04 am
    I may have figured something out. The script works fine with one color, but when I add another line, that’s when it breaks. Here’s the whole script. Maybe you can find out where I went wrong?
    colorValue2 = thisComp.layer(“Color”).effect(“Color Control 2”)(“Color”);
    colorValue3 = thisComp.layer(“Color”).effect(“Color Control 3”)(“Color”);
    colorValue4 = thisComp.layer(“Color”).effect(“Color Control 4”)(“Color”);
    colorValue5 = thisComp.layer(“Color”).effect(“Color Control 5”)(“Color”);
    colorValue6 = thisComp.layer(“Color”).effect(“Color Control 6”)(“Color”);
    colorValue7 = thisComp.layer(“Color”).effect(“Color Control 7”)(“Color”);
    colorValue8 = thisComp.layer(“Color”).effect(“Color Control 8”)(“Color”);
    colorValue9 = thisComp.layer(“Color”).effect(“Color Control 9”)(“Color”);
    colorValue10 = thisComp.layer(“Color”).effect(“Color Control 10”)(“Color”);
    colorValue11 = thisComp.layer(“Color”).effect(“Color Control 11”)(“Color”);
    colorValue12 = thisComp.layer(“Color”).effect(“Color Control 12”)(“Color”);
    colorValue13 = thisComp.layer(“Color”).effect(“Color Control 13”)(“Color”);
    if(slider==2){colorValue2};
    if(slider==3){colorValue3};
    if(slider==4){colorValue4};
    if(slider==5){colorValue5};
    if(slider==6){colorValue6};
    if(slider==7){colorValue7};
    if(slider==8){colorValue8};
    if(slider==9){colorValue9};
    if(slider==10){colorValue10};
    if(slider==11){colorValue11};
    if(slider==12){colorValue12};
    if(slider==13){colorValue13};
