Activity Forums Adobe After Effects Script UI Panel in .jsx meant to be dock-able for After Effects. keeps breaking
  • Script UI Panel in .jsx meant to be dock-able for After Effects. keeps breaking
    Posted by Spence Armajo on March 30, 2025 at 8:27 am
    I am having an issue with a Script UI Panel .jsx when making it dock-able. The Floating Window .jsx is fine, but the dockable .jsx script is having issues. I have a 3×5 grid layout for buttons that allow me to create comps at different frame rates or aspect ratios with a push of a button. What would be a good approach to solving my issue at hand?
    Here is what I have so far and what I am having some issues with.
    var button_margin = 20,
    button_width = 160,
    button_height = 35,
    top_margin = 80,
    panel_margin = 10;
    var l_button_left = button_margin,
    l_button_right = l_button_left + button_width,
    m_button_left = l_button_right + button_margin,
    m_button_right = m_button_left + button_width,
    r_button_left = m_button_right + button_margin,
    r_button_right = r_button_left + button_width,
    t_button_top = top_margin,
    t_button_bottom = top_margin + button_height
    m_button_top = t_button_bottom + button_margin,
    m_button_bottom = m_button_top + button_height,
    b_button_top = m_button_bottom + button_margin,
    b_button_bottom = b_button_top + button_height;
    var win_width = (panel_margin * 2) + (button_width * 3) + (button_margin * 4),
    win_height = (panel_margin * 2) + (button_height * 3) +(button_margin * 3) + top_margin,
    panel_right = win_width – panel_margin,
    panel_bottom = win_height – panel_margin;
    var win = new Window(‘palette’, ‘Docked Comp Creator’),
    panel = win.add(‘panel’, [panel_margin, panel_margin, panel_right, panel_bottom]),
    divider0 = panel.add(‘panel’, [l_button_left, panel_margin * 4, r_button_right, panel_margin * 4]),
    divider1 = panel.add(‘panel’, [l_button_right + (button_margin / 2), t_button_top – (panel_margin * 2.5), l_button_right + (button_margin / 2), b_button_bottom]),
    divider2 = panel.add(‘panel’, [m_button_right + (button_margin / 2), t_button_top – (panel_margin * 2.5), l_button_right + (button_margin / 2), b_button_bottom]),
    label0 = panel.add(‘statictext’, [m_button_left, panel_margin, m_button_right, button_height], ‘Click to create the desired comp.’),
    label1 = panel.add(‘statictext’, [l_button_left + (button_width / 2) – 12, t_button_top – 22, l_button_right, t_button_top – 12], ’16:9′),
    label2 = panel.add(‘statictext’, [m_button_left + (button_width / 2) – 12, t_button_top – 22, m_button_right, t_button_top – 12], ‘9:16’),
    label3 = panel.add(‘statictext’, [r_button_left + (button_width / 2) – 10, t_button_top – 22, r_button_right, t_button_top – 12], ‘1:1’),
    button0 = panel.add(‘button’, [l_button_left, t_button_top, l_button_right, t_button_bottom], ‘23.976 fps’),
    button1 = panel.add(‘button’, [l_button_left, m_button_top, l_button_right, m_button_bottom], ’24 fps’),
    button2 = panel.add(‘button’, [l_button_left, b_button_top, l_button_right, b_button_bottom], ’30 fps’),
    button9 = panel.add(‘button’, [l_button_left, m_button_top, l_button_right, m_button_bottom], ‘59.94 fps’),
    button10 = panel.add(‘button’, [l_button_left, b_button_top, l_button_right, b_button_bottom], ’60 fps’),
    button3 = panel.add(‘button’, [m_button_left, t_button_top, m_button_right, t_button_bottom], ‘23.976 fps’),
    button4 = panel.add(‘button’, [m_button_left, m_button_top, m_button_right, m_button_bottom], ’24 fps’),
    button5 = panel.add(‘button’, [m_button_left, b_button_top, m_button_right, b_button_bottom], ’30 fps’),
    button11 = panel.add(‘button’, [l_button_left, m_button_top, l_button_right, m_button_bottom], ‘59.94 fps’),
    button12 = panel.add(‘button’, [l_button_left, b_button_top, l_button_right, b_button_bottom], ’60 fps’),
    button6 = panel.add(‘button’, [r_button_left, t_button_top, r_button_right, t_button_bottom], ‘23.976 fps’),
    button7 = panel.add(‘button’, [r_button_left, m_button_top, r_button_right, m_button_bottom], ’24 fps’),
    button8 = panel.add(‘button’, [r_button_left, b_button_top, r_button_right, b_button_bottom], ’30 fps’);
    button13 = panel.add(‘button’, [l_button_left, m_button_top, l_button_right, m_button_bottom], ‘59.94 fps’),
    button14 = panel.add(‘button’, [l_button_left, b_button_top, l_button_right, b_button_bottom], ’60 fps’),
    win.bounds = [0,0,win_width,win_height];
    win.center();
    win.show();
    button0.onClick = function()
    app.project.items.addComp(‘horizontal – 16:9 – 23.976’, 1920, 1080, 1, 30, 23.976);
    button1.onClick = function()
    app.project.items.addComp(‘horizontal – 16:9 – 24’, 1920, 1080, 1, 30, 24);
    button2.onClick = function()
    app.project.items.addComp(‘horizontal – 16:9 – 30’, 1920, 1080, 1, 30, 30);
    button3.onClick = function()
    app.project.items.addComp(‘vertical – 9:16 – 23.976’, 1080, 1920, 1, 30, 23.976);
    button4.onClick = function()
    app.project.items.addComp(‘vertical – 9:16 – 24’, 1080, 1920, 1, 30, 24);
    button5.onClick = function()
    app.project.items.addComp(‘vertical – 9:16 – 30’, 1080, 1920, 1, 30, 30);
    button6.onClick = function()
    app.project.items.addComp(‘square – 1:1 – 23.976’, 1080, 1080, 1, 30, 23.976);
    button7.onClick = function()
    app.project.items.addComp(‘square – 1:1 – 24’, 1080, 1080, 1, 30, 24);
    button8.onClick = function()
    app.project.items.addComp(‘square – 1:1 – 30’, 1080, 1080, 1, 30, 30);
    button9.onClick = function()
    app.project.items.addComp(‘horizontal – 16:9 – 59.94’, 1920, 1080, 1, 30, 59.94);
    button10.onClick = function()
    app.project.items.addComp(‘horizontal – 16:9 – 60’, 1920, 1080, 1, 30, 60);
    button11.onClick = function()
    app.project.items.addComp(‘vertical – 9:16 – 59.94’, 1080, 1920, 1, 30, 59.94);
    button12.onClick = function()
    app.project.items.addComp(‘vertical – 9:16 – 60’, 1080, 1920, 1, 30, 60);
    button13.onClick = function()
    app.project.items.addComp(‘square – 1:1 – 59.94’, 1080, 1080, 1, 30, 59.94);
    button14.onClick = function()
    app.project.items.addComp(‘square – 1:1 – 60’, 1080, 1080, 1, 30, 60);
    John Martin
    replied 1 year, 5 months ago
    2 Members · 1 Reply
  • John Martin
    April 9, 2025 at 1:56 pm
    upload the current Jsx, i’ll debug it for you
