Activity Forums Adobe After Effects Expressions SCRIPT – Triggering a preview of the active composition
  • SCRIPT – Triggering a preview of the active composition
    Posted by Olivia Fitzgerald on April 7, 2023 at 12:43 am
    Hi! I’m working on setting up a script that makes a process easier for someone with a wrist injury that would usually involve a lot of clicking and dragging and scrubbing audio.
    Essentially, I need a button that when clicked on a script UI window, causes changes to the active composition, and then it immediately plays the ram preview once.
    I’m able to set exactly where I need the in and out duration to be and manipulate the settings, but everything I’ve found about actually triggering the composition’s preview doesn’t seem to work.
    Is there not a function that just hits play? Could there be an alternative that has the script preview the audio around the active time?
    Thanks.
    Olivia Fitzgerald replied 3 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
