Activity › Forums › VEGAS Pro › script to…regions to separate veg files?
  • script to…regions to separate veg files?
    Posted by Mike Costantini on August 30, 2005 at 3:56 am
    I have about 45 minutes of video on the timeline that is split up using markers, I know there is a markers to regions script, but is there a script to convert each regioned area to its own veg project? It seems that frameserving works better on short videos, even if you just select a looped area…
    Mike Costantini replied 21 years, 1 month ago 2 Members · 5 Replies
  • Gary Kleiner
    August 30, 2005 at 4:31 am
    [dax702] “is there a script to convert each regioned area to its own veg project?”
    How about saving the project with all the regions, then to have a project with only a particular region, highlight it and hit Ctrl/T?
    Gary
  • Mike Costantini
    August 30, 2005 at 7:33 am
    You’ll have to explain your reply more clearly, I understand you want me to save the project with the regions made, but then I don’t understand the next part you wrote, “then to have a project with only a particular region, highlight it and hit Ctrl T”
  • Mike Costantini
    August 30, 2005 at 7:46 am
    ok, this Ctrl T is a scary thing, it seems to get rid of everything that isn’t selected
  • Gary Kleiner
    August 30, 2005 at 4:29 pm
    Exactly.
    Gary
  • Mike Costantini
    August 30, 2005 at 4:31 pm
    i was able to get it accomplished by having two instances of vegas open, and just cutting and pasting each region, only problem was that i lost my track motion settings and video fx settings, but it was easy to fix..
