Activity Forums Adobe After Effects Expressions Script to trim end point of layer when opacity is at 0%.
  • Script to trim end point of layer when opacity is at 0%.
    Posted by Kyle Ussery on October 5, 2020 at 5:44 pm
    Hello all,
    I’d like to create a script that looks a selected comp (or selected layers), and trims the end point of each layer when the opacity is at 0%.
    The context is Power Point presentations. I have the slides on a time line, each with an expression that looks at a .csv file, turning the opacity to 0% when timeToCurrentFormat() reaches the specified time.
    The expression:
    f=footage(“TimeCode.csv”).dataValue([1,index-1]);
    s=timeToCurrentFormat();
    if (s<f)100; else 0;
    <font face=”inherit”>The expression works great, the only issue is the render time. Some of these are 100+ layers, and I feel they would render much more quickly if the end points were trimmed so the expression on each layer wasn’t running the whole time it renders. Of course I could do it </font>manually<font face=”inherit”>, but that too takes a fair amount of time.</font>
    <font face=”inherit”>Any ideas?</font>
    Thanks in advance,
    Kyle
    Kyle Ussery replied 5 years, 11 months ago 3 Members · 4 Replies
  • Stephen Dixon
    October 6, 2020 at 2:19 am
    Your question is very broad; that would definitely be something that you could script. Either to create the comp from scratch given the CSV, or to trim the ends based on the opacity. https://docs.aenhancers.com is the place to go for extendscript documentation.
  • Filip Vandueren
    October 6, 2020 at 2:52 pm
    I’ve written a script for this some time ago:
    it checks if the first and/or last keyframe of opacity and/or scale == 0 and trims to those points.
    Here it is:
    https://we.tl/t-c4ff1fW2mC
    Choinks – date modified is 2008, I’m getting really old 😉
    Still works though!
  • Filip Vandueren
    October 6, 2020 at 2:53 pm
    Oops, but that does mean you’d have to create keyframes though.
  • Kyle Ussery
    October 10, 2020 at 11:55 pm
    Thanks Filip, I’ll check this out. I usually always gain some new knowledge from scripts, even if the scenario isn’t exactly right.
