Activity › Forums › Adobe After Effects Expressions › script to search for a layer name and return it’s index
  • script to search for a layer name and return it’s index
    Posted by Rob Packer on February 26, 2022 at 7:37 am
    I am trying to write a bit of code I can call to search within a composition for a layer name and return the layer’s index, so I can then perform some actions on it.
    The following shows that the variables have the expected values when running, but once it gets back to the code it was called from the layIndex variable shows as undefined.
    How do I get the layIndex value to be returned?
    function sLN(compToSearch, layNS, layIndex){
    // compToSearch: name of composition to search (a global variable) , layNS: the layer name I'm searching for (a global variable), layIndex: the index of the layer that was searched for
    var K=compToSearch.numLayers, layer;
    for (var k = 1; k<=K; k++) {
    if (compToSearch.layer(k).name === layNS) {layer = compToSearch.layer(k);
    break;
    layIndex = k;
    Rob Packer replied 4 years, 7 months ago 2 Members · 2 Replies
  • Andrei Popa
    February 26, 2022 at 9:56 am
    I don’t think you need a function for that. This should work:
    compToSearch.layer(layNS).index
  • Rob Packer
    February 26, 2022 at 12:09 pm
    Thank you once more Andrei!
    Simple and elegant.
