Activity Forums VEGAS Pro Script to restore deleted audio to video event — vegas pro 13
  • Script to restore deleted audio to video event — vegas pro 13
    Posted by Lars Hansen on March 22, 2017 at 8:08 pm
    Looking at a few old forums there appears to be a script called “RecreateAudioEvents.js” that restores deleted audio associated with a video event.
    Does anyone know where I might get a copy of such a script and if it works in SVP 13?
    https://vimeo.com/longdcycler
    Lars Hansen replied 9 years, 6 months ago 4 Members · 4 Replies
  • László Kovács
    March 22, 2017 at 8:37 pm
    I know for sure Vegasaur has this functionality.
    So if you don’t find that script, it may worth to give Vegasaur a try.
    Best regards
    László Kovács
  • Paul Berk
    March 23, 2017 at 4:36 am
    László .. that script in Vegasaur must be for the original camera audio for a particular video clip .. easy enough to find and match to a video event but I can’t see this working for ‘wild sound” .. I think the OP is talking about sound from his H6 Zoom, not the camera.
  • Graham Bernard
    March 23, 2017 at 5:33 am
    I use the Mighty Excalibur by Edward Troxel. The A/V restore Icon sits loud and proud on my Toolbar.
    OK, just went down Memory Lane with some Google searching. I found the script on the Calderwood site. I haven’t used the script nor can I vouch for it in any way!:
    * (re)create audio parts on seperate audio track for all selected video events
    import System.Windows.Forms;
    import Sony.Vegas;
    try {
    // create new target audio track
    var targetTrack = new AudioTrack(-1,”Missing Audio”);
    Vegas.Project.Tracks.Add(targetTrack);
    // step through all selected video events:
    for (var track in Vegas.Project.Tracks) {
    for (var evnt in track.Events) {
    if (!evnt.Selected || evnt.MediaType != MediaType.Video) continue;
    // create a fitting audio event and add to target audio track:
    var audioEvent = new AudioEvent(evnt.Start,evnt.Length);
    targetTrack.Events.Add(audioEvent);
    // step through all events of selected video event
    for (var tke in evnt.Takes)
    // find first audio stream in this takes media
    var aviFile = new Media(tke.MediaPath);
    for (var stream in aviFile.Streams)
    if (stream.MediaType != MediaType.Audio) continue;
    // create new take out of this audio stream
    var newTake = new Take(stream,tke.IsActive);
    // add it to target audio event (must be done before anything else!!)
    audioEvent.Takes.Add(newTake);
    // fit offset to video event
    newTake.Offset = tke.Offset;
    break; // we assume there’s only one audio part in any avi file
    audioEvent.Selected = true;
    } catch (e) {MessageBox.Show(e);}
    This needs to be reworked for the new owners of VP. Here’s that Calderwood site: https://s92274348.onlinehome.us/vegas.html
    * Grazie
  • Lars Hansen
    March 25, 2017 at 7:13 pm
    Thankyou kindly Grazie! This appears to be the ticket!
    I’ve downloaded the collection of scripts via the site you referenced and what a list! I assume that some of these are outdated/redundant now?… That said, there are quite a few scripts there I have moved into my Vegas script folder as they’re great short cuts to completing more time consuming tasks (e.g “Normalize”, which normalizes audio for an entire track!).
    I have tested the “Recreate Audio Events” from the collection (which is the script I assume you pasted above) and it appears do exactly what I want.
    For those who want to learn a little more about installing and using scripts here’s a good video by Scott Eggleston: https://www.youtube.com/watch?v=krySUGsudsI
    Cheers! LDC
