Activity Forums Adobe After Effects Script to remove keyframes that are the same
  • Script to remove keyframes that are the same
    Posted by James Peres on June 11, 2012 at 12:00 pm
    Hi, I am having a little trouble figuring out how to go about a script to clean up the Convert Expressions to Keyframes process. I basically end up with a lot of keyframes that are essentially the same (the result of the hold keyframe). I export XML using those keyframes to having a lot of unnecessary keyframes slows things down. Is there a way to remove keyframes that don’t change value?
    I’ve come across JD_SmartBaker.jsx, but no matter what I set the tolerance to it doesn’t remove many frames.
    Mac Pro 4,1 Quad Core 2.66
    Dan Fredley replied 14 years, 2 months ago 3 Members · 4 Replies
  • Roland R. kahlenberg
    June 11, 2012 at 7:09 pm
    I don’t know of a script but you can right-click on a KF and choose, Equal KFs to select all KFs that are of the same value as the KF where your Timeline Indicator is parked at.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Dan Fredley
    June 21, 2012 at 1:56 am
  • James Peres
    June 21, 2012 at 5:58 pm
    Hey! Thanks for the reply. I tried smart baker and it doesn’t work: if I use a threshold high enough to remove equal keyframes, it also begins removing animation curve frames. I only want to remove keyframes that are equal.
    James
  • Dan Fredley
    June 21, 2012 at 6:43 pm
    Try setting the threshold to 10.
