Activity › Forums › Adobe After Effects Expressions › Script to make new folders in the finder ?
  • Script to make new folders in the finder ?
    Posted by Daniel Crooks on September 11, 2009 at 7:29 am
    hi
    I have a script that is setting up a stack of comps and then queing them to be rendered. Normally i’d be ok to render 30 or so movies into a folder but the problem is I now want to use DPX sequences instead of quicktime movies. each of the sequences are 20000+ frames so I need to put each sequence into it’s own folder. I can’t work out a way for the script to create a new folder for the render location filepath. I tried simply adding it into the output filepath but of course came back with an error saying that folder doesn’t exist. Is it even possible to create/delete folders via the script ?
    cheers../daniel
    Dan Ebberts
    replied 16 years, 4 months ago
    3 Members · 6 Replies
  • Dan Ebberts
    September 11, 2009 at 11:34 am
    You should take a look at the Folder object constructor section in Adobe’s JavaScript Tools Guide, but basically it’s like this:
    myFolder = new Folder (theFolderPath);
    Dan
  • Daniel Crooks
    September 14, 2009 at 11:44 am
    hi Dan
    thanks for pointing me onto the Javascript Tools Guide, I’ve been plodding along with the After Effects scripting guide which is a bit thin on the basics. All up running sweetly now.
    cheers../ Daniel
  • Adam Ghering
    April 18, 2010 at 2:19 am
    Ok so I have tried numerous ways to create a folder on the drive with no luck…every time I use the examples that people have posted it doesn’t work. I have tried your above examples but I still have no luck. this is what I have tried
    myfolder = new File(“c:\\Newfolder\\”);
    didn’t work so I found a command in the java script toolkit and tried this
    Folder.create(“c:\\Newfolder\\”);
    this gives the error that Folder.create is undefined so I tried this
    Folder.create(myfolder);
    still no luck
    also
    myfolder = Folder.create(“c:\\Newfolder\\”);
    some of the examples seem to run without errors but there is no folder created in the directory.
    What am I missing.
  • Dan Ebberts
    April 18, 2010 at 1:51 pm
    Try it this way:
    var myFolder = new Folder(“/c/Newfolder”);
    myFolder.create();
    Dan
  • Adam Ghering
    May 19, 2010 at 11:56 pm
    Thank you Dan…that worked
    What about creating a wildcard for looking for a script like
    /c/user/*.jsx
    and having the script return whatever it .jsx it finds there.
    thanks,
  • Dan Ebberts
    May 20, 2010 at 12:04 am
    Try this:
    var myFiles = myFolder.getFiles(“*.jsx”);
    Dan
