Activity › Forums › Adobe After Effects Expressions › Script to export PNG
  • Script to export PNG
    Posted by Jason Hare on January 29, 2015 at 9:38 am
    I have found a script that allows a PNG file to be exported at the press of a button. I have discovered that the resolution of the PNG is based on the Resolution/Draw Down Sample Factor of the Project Display window.
    Is there a simple line that I can add to the script to force this window to be full quality prior to exporting the PNG? Would something like this work?
    app.project.item(index).resolutionFactor[1,1]
    Jason
    Xavier Gomez replied 11 years, 7 months ago 2 Members · 1 Reply
  • Xavier Gomez
    January 29, 2015 at 3:28 pm
    you forgot the “=”.
    // store old value
    var oldResFactor = comp.resolutionFactor;
    // set [1,1]
    comp.resolutionFactor = [1,1];
    /* DO STUFF WITH THE COMP */
    // at the end, restore the old value:
    comp.resolutionFactor = oldResFactor;
    Xavier
