Activity Forums Adobe After Effects script to create text layer with specified properties
  • script to create text layer with specified properties
    Posted by oliver turm on February 1, 2024 at 10:39 pm
    I need to write a script which will create a text layer that:
    – is positioned in the lower left corner
    – displays the comp name
    – is white, with drop shadow, a specific font and size
    It all works fine until I get to the text properties and then I keep getting “unable to execute script at line #. undefined is not an object. I’ve tried both Bard and ChatGPT to help me figure this out but to no avail. Here’s what I’ve got
    var compName = app.project.activeItem.name;
    var textLayer = app.project.activeItem.layers.addText(“”); // Create with empty initial text
    var myTextDocument = new TextDocument(textLayer);
    myTextDocument.text = compName;
    myTextDocument.textProperty.fontSize = 30; // Set point size
    myTextDocument.textProperty.fillColor = [255, 255, 255]; // Set color to white
    textLayer.property(“Position”).setValue([50, app.project.activeItem.height – 50]);
    var dropShadow = textLayer.effects.addEffect(“Drop Shadow”);
    dropShadow.setProperty(“Color”, [0, 0, 0]);
    dropShadow.setProperty(“Opacity”, 50);
    dropShadow.setProperty(“Blur Radius”, 5);
    app.project.activeItem.selectedLayers = [textLayer];
    Thanks for any help.
    oliver turm replied 2 years, 7 months ago 2 Members · 2 Replies
  • Walter Soyka
    February 1, 2024 at 11:47 pm
    Text layers, text properties, and text documents can be a little tricky. You can read all about it in the docs here:
    https://ae-scripting.docsforadobe.dev/other/textdocument.html
    In the meantime, try this for your script:
    var textLayer = app.project.activeItem.layers.addText(compName);
    var textProp = textLayer.property("Source Text");
    var textDocument = textProp.value;
    textDocument.resetCharStyle();
    textDocument.fontSize = 30;
    textDocument.fillColor = [1, 1, 1];
    textDocument.applyFill = true;
    textDocument.justification = ParagraphJustification.LEFT_JUSTIFY;
    textProp.setValue(textDocument);
    textLayer.property("Position").setValue([50, app.project.activeItem.height - 50]);
    var dropShadow = textLayer.property("Effects").addProperty("ADBE Drop Shadow");
    dropShadow.setProperty("Color", [0, 0, 0]);
    dropShadow.setProperty("Opacity", 50);
    dropShadow.setProperty("Blur Radius", 5);
  • oliver turm
    February 3, 2024 at 12:45 am
    I Walter, thanks so much for taking a look. That works great with the exception of the dropshadow. In other words, disabling the last 5 lines does exactly what I was after. I’ll take a closer look at the link you sent. Thanks again.
