Activity Forums Adobe After Effects Expressions Script to change text within expressions
  • Script to change text within expressions
    Posted by Riccardo Sinti on November 16, 2012 at 10:40 pm
    I set up a control layer to drive some expressions. I want to use this layer to control layers in a duplicate comp but now I have to change the wording in all the expressions to reference the new comp.
    Is there a script that can look through a comp’s expressions and change, say, “comp(“comp1”) to comp(“Comp2”), or any other replacement that needs to be made?
    Riccardo Sinti replied 13 years, 10 months ago 2 Members · 2 Replies
  • Dylan Winter
    November 20, 2012 at 8:44 pm
    Seems like a fun challenge. I’m trying to write a script for you right now, but I’m getting hung up on calling all the different possible properties for a layer, given the fact that I can’t predict what plugins you might have expressions on and haven’t found a good way to potential wild cards via script. Would it still be helpful to you if this worked only with transform properties?
  • Riccardo Sinti
    November 26, 2012 at 3:33 pm
    Wow, thanks for the effort! I’ve been away for the holidays so sorry for a late response.
    Though the project I was working on is over now and I just slogged through changing all the layer references in the expressions to get it done, any help in a script would be very useful to me and, I would imagine, others as well.
    Transform properties only would certainly be useful in the future and could be a starting point for you and other great minds to create a script that could streamline this process.
    Just a thought prefaced by the fact that I know nothing about writing scripts, but is it possible to direct a script to just look at a comp’s layers for any expressions regardless of whether or not it lives in a transform property or an effect?
    Thank You
