Activity › Forums › Apple Final Cut Pro Legacy › script to apply an offset to a series of images?
  • script to apply an offset to a series of images?
    Posted by Jeff Bach on January 20, 2013 at 5:04 pm
    Hi all
    Current project involves a large sequence of time lapse still images. FCP handles this nicely so far. Once I have the set of images sitting on the timeline I then want to move each image over to the right (+ve x direction)by 120 pixels. Easy to do per image but I need to apply this offset to hundreds of images. Has anyone used Apple script or FXscript or ?? to do this to a series of still images? Is there another way to do it that I am missing?
    Jeff Bach
    Quietwater Films
    Madison, WI.
    Rafael Amador replied 13 years, 8 months ago 3 Members · 4 Replies
  • Bret Williams
    January 20, 2013 at 8:08 pm
    Assuming you want to keep them in tact as a sequence, just nest them, then adjust the nest position.
  • Rafael Amador
    January 21, 2013 at 3:26 am
    [Jeff Bach] “Current project involves a large sequence of time lapse still images. FCP handles this nicely so far. Once I have the set of images sitting on the timeline I then want to move each image over to the right (+ve x direction)by 120 pixels. Easy to do per image but I need to apply this offset to hundreds of images. Has anyone used Apple script or FXscript or ?? to do this to a series of still images? Is there another way to do it that I am missing?”
    If all the images has the same center point (0,0):
    – Change the center for the first still (120,0).
    – Then click on the still and “Copy” (Cmd-C).
    – Select all the stills on the sequence and LEFT-Click > Paste Attributes > Basic Motion.
    All the stills will get the new center point.
    [Bret Williams] “Assuming you want to keep them in tact as a sequence, just nest them, then adjust the nest position.”
    That don’t work. You will get a black band on one side.
    rafael
    http://www.nagavideo.com
  • Bret Williams
    January 21, 2013 at 4:43 am
    Of course you’re right. I was thinking like an animated sequence, where either method will leave the band. But if these images have extra space, then paste attributes would work. Or nest them in a comp larger than the current sequence. For example nest them, then simply change the nest size to 3000 x 3000 or whatever is needed to see the extra image. I do it all the time.
  • Rafael Amador
    January 21, 2013 at 5:30 am
    I know you had your head on something else, Bret 🙂
    rafael
