Activity Forums Adobe After Effects Script that rescales a mask path
  • Script that rescales a mask path
    Posted by Martin Dumas on January 16, 2023 at 2:12 pm
    Hi I’m new here.
    How to programmatically re-scale a Mask Path (or its “bounding box”, or the vertices of its shape ??) that’s in a Solid layer ?
    Also, the rescaled mask has to remain centered on its layer.
    Thanks a lot !!
    Martin Dumas replied 3 years, 7 months ago 2 Members · 2 Replies
  • Max Haller
    January 18, 2023 at 2:19 am
    Hey Martin can you give a little more detail about what you want to do?
    When i make a solid layer and then draw a mask it normally rescales with the layer already so im not sure what you’re asking for exactly.
  • Martin Dumas
    January 21, 2023 at 8:27 pm
    I want to re-scale the shapes inside a mask instead of the mask itself.
    I’m using glow effects. If I dont scale down the shapes (generated by auto-trace), the glow effect is cut off at the bounds of the mask.
