Activity Forums Adobe After Effects Expressions Script request, reveal in timeline
  • Script request, reveal in timeline
    Posted by Ben Pohl on February 22, 2014 at 7:37 pm
    Hello,
    I originally posted this on AE Enhancers, but I probably should’ve posted here first. 🙂
    I do a lot of creating/animating with shape layers. And I’m frequently trying to access the Path of shape layers. The constant twirling/untwirling of the shape layer properties is a big time killer. The only way I know how to quickly reveal the paths of a shape layer is to search in the comp window for “path”.
    I did a screen capture of exactly what I’m trying to do:
    https://youtu.be/x0kadW2m66k
    Can a script reveal all the paths of a selected shape layer? I’d like to add it to ftToolbar, it would really speed things up.
    I’d be willing to pay a scripter for this, if it helps.
    Ben Pohl
    bad-pixel.com
    Filip Vandueren replied 5 years, 3 months ago 4 Members · 4 Replies
  • Dan Ebberts
    February 22, 2014 at 9:13 pm
    Scripting has really limited control of the UI, so, unfortunately, I don’t think it’s possible to operate specific twirlies from a script.
    Dan
  • Sebastian Moreno
    May 13, 2021 at 12:27 pm
    I was looking for the same script but didn’t find something similar so I wrote a quick and dirty solution. Works only with custom paths and creates a keyframe at current time (can be removed with further code)
    function Path() {
    var selectedLayers = app.project.activeItem.selectedLayers;
    for (var x = selectedLayers.length - 1; x >= 0; x--) {
    var currentLayer = selectedLayers[x];
    var Path = currentLayer.property("ADBE Root Vectors Group").property("ADBE Vector Group").property("ADBE Vectors Group").property("ADBE Vector Shape - Group").property("ADBE Vector Shape")
    Path.selected = true;
    app.executeCommand(2701);
    app.executeCommand(2387);
    Path();
  • Filip Vandueren
    May 15, 2021 at 1:28 pm
  • Filip Vandueren
    May 18, 2021 at 10:10 am
    Here it is rewritten for specifically revealing only all paths of the selected layers. There may be a more efficient way to first find all Paths in the selected layers, my extendscripting is a bit rusty.
    app.beginUndoGroup("reveal Paths");
    selLayers = app.project.activeItem.selectedLayers;
    props=[];
    function findPaths(prop) {
    if (prop.matchName == "ADBE Vector Shape") {
    props.push(prop);
    if (prop.numProperties) {
    for (var i=1; i<=prop.numProperties; i++) {
    findPaths(prop(i));
    for (l in selLayers) {
    selLayer=selLayers[l];
    if (selLayer.matchName == "ADBE Vector Layer") {
    numGroups = selLayer("ADBE Root Vectors Group").numProperties;
    findPaths(selLayer("ADBE Root Vectors Group"),props);
    // prop we want to reveal:
    originalExpression=[];
    for (p=0; p < props.length; p++) {
    prop = props[p]
    originalExpression[p] = prop.expression;
    prop.expression= "1/0"; // create an expression error
    //reveal expression errors:
    app.executeCommand( app.findMenuCommandId("Reveal Expression Errors") );
    $.sleep(1); // wait 1 ms
    // reset expression to previous value
    props[p].expression = originalExpression[p];
    app.endUndoGroup();
