Activity › Forums › Adobe After Effects Expressions › Script question
  • Dan Ebberts
    October 12, 2010 at 8:11 pm
    The exact error message would be helpful (and the expression, if it’s an expression error).
    Dan
  • Mike Park
    October 12, 2010 at 8:16 pm
    Error as follows:
    After Effects warning:Expected:’
    Expression disabled.
    Error occurred at line 1.
    Comp:’Comp 1′
    Layer: 4 (‘Red Solid’)
    Property: ‘Center’
    It generates this error for every property which is able to have an expression applied.
    The expression generated is as follows for that particular property:
    thisComp.layer(“Red Solid”)undefined(“Effects”)(“Circle”)(“ADBE Circle-0001”)
    If you take out the undefined, it works fine. I don’t know what is creating the undefined in the middle of the expression.
    Thanks for the look.
  • Mike Park
    October 12, 2010 at 8:23 pm
    I have narrowed the problem down to the “else if” statement at the end of the LinkAll function.
  • Dan Ebberts
    October 12, 2010 at 9:03 pm
    It looks like your main routine calls LinkAll() with only one parameter. If you don’t already, learn to set breakpoints, examine the call stack and the data browser.
    Dan
Page 2 of 2
