Activity Forums VEGAS Pro Script problem for Ed
  • Script problem for Ed
    Posted by Kim Nance on March 23, 2006 at 11:11 am
    Hi Ed
    I have cross posted this on your forum, and also emailed the author, John Meyer. I understand it is not your script, but seeing I got it from your website, I thought you might be able to add some educated advice.
    I have just used the JHM_Delete_from_cursor_to_event_start.js script, and it work brilliantly. Or so I thought, until I realized that it was ALSO slipping the material inside the following events by the same amount deleted. That is, all following events rippled correctly, had the correct duration, but had been slipped by the deleted duration. The AutoRipple button made no difference. Could this be because I am using Vegas 6d, and the script was written 3 years ago? Any help greatly appreciated.
    Regards
    Kim Nance
    Armadillo Post
    Kim Nance replied 20 years, 6 months ago 2 Members · 3 Replies
  • Edward Troxel
    March 23, 2006 at 2:51 pm
    [Kim Nance] “Could this be because I am using Vegas 6d, and the script was written 3 years ago?”
    Actually… yes it could. Vegas 6 changed some things that I’ve had to work around in Excalibur. Some older scripts have not been modified with these changes. If you look in the script, this command is used in a couple of places: AdjustStartLength. Unfortunately, the way this command works changed between Vegas 5 and Vegas 6.
    You might try commenting out this line (put // in front of it) and see if that helps:
    evnt.ActiveTake.Offset = DeleteFrames+evnt.ActiveTake.Offset;
    Edward Troxel
    JETDV Scripts
  • Edward Troxel
    March 23, 2006 at 5:08 pm
    Revised versions have been received from John and uploaded. Check your other post.
    Edward Troxel
    JETDV Scripts
  • Kim Nance
    March 23, 2006 at 8:09 pm
    Thanks for this – can’t wait to get back to being a ‘cuts-only speed demon.’
    Regards
    Kim Nance
    Armadillo Post
