Activity Forums Adobe After Effects Expressions Script-Pick Whip?
  • Posted by Jacob Danell on February 3, 2014 at 10:07 pm
    Hi! I’m trying to create a pick whip in AE Scripts but can’t make it to work.
    I want to achieve this expression:
    thisComp.layer('RealCameraMovement').transform.position+value
    but the only way I have found working is by hardcoding the expression like this in the script:
    selectedLayer.property("position").expression = "thisComp.layer('" + scriptName + "').transform.position+value";
    But this way, if the user later change the Null-object(the nulls name-variable is scriptName) the expression doesn’t update like if I would have made this inside AE.
    Are there any way to create a pick whip in AE scripts so if the Null is later renamed the expression still works?
    Jacob Danell replied 12 years, 7 months ago 2 Members · 6 Replies
  • Dan Ebberts
    February 3, 2014 at 11:54 pm
    Try switching the way you use ‘ and ” so that the expression ends up with double quotes defining the null’s name, like this:
    selectedLayer.property(“position”).expression = ‘thisComp.layer(“‘ + scriptName + ‘”).transform.position+value’;
    Dan
  • Jacob Danell
    February 4, 2014 at 10:52 am
    Didn’t work =/ Guessing it’s nothing that is able to be done trough scripting.
  • Dan Ebberts
    February 4, 2014 at 4:43 pm
    I don’t think it has anything to do with scripting. If you pickwhip this expression:
    thisComp.layer(“Layer 1”).transform.position
    and change it to this (replace double quotes with single quotes like your script uses):
    thisComp.layer(‘Layer 1’).transform.position
    the expression won’t update when you change the name of Layer 1.
    Dan
  • Jacob Danell
    February 5, 2014 at 1:05 pm
    I tried as you said, chainging ‘ to ” and ” to ‘ so the script applied
    selectedLayer.property("position").expression = 'thisComp.layer("' + scriptName + '").transform.position+value';
    The code in AE looked like this:
    thisComp.layer("nullControll").transform.position+value
    and after tried to change the name of the null, the name didn’t change in the expression
  • Dan Ebberts
    February 5, 2014 at 6:15 pm
    Interesting. It works fine for me. What version of AE?
    Dan
  • Jacob Danell
    February 11, 2014 at 9:15 am
    I found the problem… My script exedently created two layers with the same name and there is where the problem happened. Than’s Dan for the help!
