Activity Forums Adobe After Effects Expressions Script or tool to toggle visibility(or audio) globally for certain sub layers?
  • Script or tool to toggle visibility(or audio) globally for certain sub layers?
    Posted by Greg C neumayer on September 27, 2016 at 9:55 pm
    Hi gang.
    My client wants me to export separate Voice-over, Music, SFX, and Picture versions of our project.
    Many of the VO and SFX clips are pretty deep in sub-layers, since we’re animating mouths to voice clips.
    Is there a way (tool/expression/product) to go in one time and re-label everything so that it can be effectively toggled at the top level so that I can more easily make these versions?
    For example, I go in and everything that’s a sound effect, I start it’s layer name with “sfx…” Then, at the top level, I run a script that will turn on the visibility/audio only for layers that start with “sfx” so that I can do just a pass of these files.
    Anything out there or any ideas?
    Greg
    Greg C neumayer replied 9 years, 11 months ago 2 Members · 2 Replies
  • Xavier Gomez
    September 27, 2016 at 10:16 pm
    The script Zorro will do most of this i believe.
    https://aescripts.com/zorro-the-layer-tagger/
    Xavier
  • Greg C neumayer
    September 28, 2016 at 12:39 am
    Yeah, that’s almost perfect, but it looks like it’s limited to only the current comp. I need to be able to set up my project so that later I can toggle those little layers down in sub-comps.
