Activity › Forums › Adobe After Effects Expressions › Script mask shape to motion path
Benoit Kergosien replied 11 years, 5 months ago 2 Members · 12 Replies
Benoit Kergosien
March 25, 2015 at 11:40 amFound!
var N=myLayer.property(“Effects”).numProperties; and not var N=myLayer.numProperties;
Benoit
Benoit Kergosien
April 18, 2015 at 7:19 pmHi,
Unfortunately I’ve got another problem :
the path copied via my script isn’t as accurate than the one copied manually.
See the image attached!
my code:
var myComp=app.project.activeItem;
var myLayer=myComp.selectedLayers[0];
var myMask=myLayer.mask(1);
var times=new Array();// Creation of Effects
var mynumEffects=myLayer.property(“Effects”).numProperties;
myLayer.property(“Effects”).addProperty(“Point Control”);// Customisation of Effects
var Target=myLayer.property(“Effects”).property(mynumEffects+1);
Target.name=”myTarget”;
var myTarget=Target.property(“Point”);
mynumEffects+=1;// Read path content
var shape=myMask.maskPath.value,
verts=shape.vertices,
inTan=shape.inTangents,
outTan=shape.outTangents,
numVerts=verts.length;// In case of closed shape
if (shape.closed) {verts.push(verts[0]); inTan.push(inTan[0]); outTan.push(outTan[0]); numVerts++;};/*
// Inject 2D tangents into 3D property (tangents for a motion path always 3D, even for 2D)
for (var k=0; k < numVerts; k++) inTan [k][2] = outTan[k][2] = 0;
*/// Interval of time within wich the animation is adapted
var step = 2/(numVerts-1);
for (k=0; k
