Activity Forums Adobe After Effects Expressions [Script] How to select random keyframes?
  • Filip Vandueren
    November 12, 2020 at 9:28 am
    Define random ? How many ? If you have a comp with 200 keyframes, random could return 0 keyframe or 200. Do you need a minimum? Or 50% at random ?
  • Filip Vandueren
    November 12, 2020 at 9:39 am
    You could change line 53 to:
    prop.setSelectedAtKey(ii, Math.random()<0.5);
    for a 50% probability a property will be selected.
    and change line 52 to:
        for (var ii = 1; ii <=prop.numKeys; ii++) {
    To evaluate all keys of the properties, not just those within the workarea.
    Line 22-25 & 42-50 have no function in that case and can be commented out.
    I haven’t tested this though.
