Script for stretch & compress in a event
Posted by Ramil Pescador on October 28, 2018 at 12:00 amIs there a existing script to set back to normal speed a compressed/stretched clip?
And also if there is a script that would set clip to a certain speed by a percentage duration?
Like for example you selected a clip & you want to slow it down or sped it up by 30% or 50% or 70%, depending on what is set/programmed on the script.Thanks..
Aleksey Tarasov replied 7 years, 10 months ago 5 Members · 7 Replies -
Francois Pénzes
October 29, 2018 at 12:05 amHi Ramil
You may want to read and try this out:
https://library.creativecow.net/articles/harvey_jim/excalibur.php
Since you do not mention what version of Vegas you are working with, there is a link at the bottom of the read to a trial version.
Cheers !
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
Vegas Pro 14, User since Vegas 3.0\’\’When the cutting stops, the editing begins…\’\’
Pete Baratta
October 30, 2018 at 10:30 amHello Ramil,
I just add a velocity envelope to the event. If you right click on the first key you can set/reset the percentage
of compression or stretch.
Pete. -
Francois Pénzes
October 30, 2018 at 8:39 pmHi Pete
My take on his question is that he want’s to apply it to the whole project, hence the script to save time, especially when you have more than 2 or 3 events.
Cheers !
Ramil Pescador
October 31, 2018 at 7:29 amThat’s a good one but what i needed is something applicable for multiple clips..like for example i want clips 1, 2, 3, 4 to be 50% slow, then 5, 6, 7, 8 to be 30 % then same also to other clips. Selective copying paste & event attributes is my workaround with these but if other alternative like script is available to make it faster then i’ll go for it.
Ramil Pescador
October 31, 2018 at 7:36 amThank you @Francois, but I already have purchased Vegasaur & it would cost me to buy again a extension program for Vegas with nearly same identical functions, i just needed these kinds of script if it’s available for free & if anyone has this kind of script to share. But if its not available then its ok.
Edward Troxel
October 31, 2018 at 3:14 pm -
Aleksey Tarasov
October 31, 2018 at 3:54 pmRamil,
In Vegasaur’s Quick Properties set Playback Rate to the desired speed (1 = 100%, 2 = 200%, 0.5 = 50% i.e. half speed):
