Activity Forums Adobe After Effects Expressions script for quickly chopping up giant image in AE?
  • script for quickly chopping up giant image in AE?
    Posted by Jimmy Brunger on July 30, 2009 at 2:49 pm
    Hi all,
    We want to do a giant video wall in AE and it’s matte/frame will be upto 30,000 pixels wide, so I know we need to chop it up into manageable pieces and slot/parent them back together in AE…
    I read in an old post there is a script that can achieve this pretty quickly, but after a bit of googling I can’t find it. Any ideas?
    Originally post here: https://forums.creativecow.net/thread/2/958020#958069
    Cheers
    Production Premium CS4 – Mocha v1.2.3 – FCP 5.1.4
    MacPro Quad 3GHz / ATI 1900XT / 8GB RAM / OSX 10.4.11
    30″ ACD / Decklink SP / SONY PVM-20M4E/ Wacom Intuos 3 A4 / XServe / United Digital RAID
    Production Premium CS2 – Combustion 3 – Mocha v1.0.1
    Win XP Pro 32 / Dell Precision T3400 Q6600 / 4GB RAM / NVidia Quadro570 / DeckLink Pro / Roland DS-5s / Sony BVM-20G1E / 2 x Dell 2007FP / Wacom Intuos 3 A4 / 320GB boot/800GB RAID-0
    Akshay Kamath replied 15 years, 5 months ago 4 Members · 6 Replies
  • Micheel Leavitt
    July 30, 2009 at 3:59 pm
    Hi, I think this may be what you are looking for:
    https://www.redefinery.com/ae/view.php?item=rd_Slicer
    It even has a dockable UI panel to make things easy. BTW, just curious, why do you need a 30Kx30K video layer? It seems a little much…
  • Jimmy Brunger
    July 30, 2009 at 4:14 pm
    Cheers for that. We’ve got a massive map of europe and it will be made up from hundreds of bits of video, starting from one of those videos full screen and pulling way out to reveal the whole continent. BIIIIG!
  • Micheel Leavitt
    July 30, 2009 at 4:15 pm
    **If you want the layers to be sliced into rectangles, this could work too:
    https://nabscripts.com/downloads_en.html
  • Filip Vandueren
    July 30, 2009 at 7:27 pm
    I think both these scripts start from an already big footage and chop it up using masks, anchorpoints and position.
    However. This would mean you’re going to wind up with multiple instances of a 30K by 30K image. Even more of a pain to handle.
    I don’t even know how you would create that image to begin with… I guess Photoshop can do it if you have ages of time. Just 1 layer in RGBA would be 3.35 Gigabytes if I’m correct.
    I’m pretty sure After Effects will not even try to import, let alone display that.
    Can you describe the workflow you have in mind in a bit more detail ?
    This is going to prove quite a challenge, and will be very interesting if you pull it off, so please share.
  • Micheel Leavitt
    July 31, 2009 at 6:39 am
    If you are not animating scale, and doing it with a camera, you should probably look for a script that will take all of those pieces made with the grid script and then have it save each one as a .psd or high res JPEG, and then maybe find a way to quickly replace each original piece with the new .psd/.jpeg images. Theres a keyboard shortcut to do one at a time, but if you could find a script that would be handy. Good luck!
  • Akshay Kamath
    April 23, 2011 at 6:41 pm
    thanks akshay
