Activity › Forums › Adobe After Effects Expressions › Script for creating a fibonacci based circle-animation
  • Script for creating a fibonacci based circle-animation
    Posted by Anne Meo on December 18, 2010 at 2:30 pm
    Hi to all,
    i have a request animating a background texture. it nedds to have several circle (not rings), which should have 3 fix colors and scaled in relation to the fibonacci rule, 1+2=3, 2+3=5, 3+5=8, and so on.
    so i basically need some kind of emitter, which creates on circle, slowly scaling bigger and fading slowly to transparent at the end of lifespan. the following created circles should be in relation to fibonaccis rule, smaller or bigger. all that based casually based on the three colors.
    in total, there should be around 10-12 circles, more or less constantly created and dying.
    got it? if not ask, i´ll explain as much as is necessary to understand
    best to all
    Ann
    Anne Meo replied 15 years, 9 months ago 3 Members · 4 Replies
  • Chris Wright
    December 18, 2010 at 9:35 pm
    maybe use particular, regular birth to death opacity and random start size dependent on
    //scale fibonacci
    var limit=14; // or random size start
    if (limit>timeToFrames())
    [b2(timeToFrames()),b2(timeToFrames())];
    else
    [b2(limit),b2(limit)]
    function b2(n)
    prev1=0, prev2=1;
    for( i=0; ihttps://technicolorsoftware.hostzi.com/
  • Anne Meo
    December 19, 2010 at 12:04 am
    Thanks a million!
    tried it and get an error message (on line 17)
    also, it´s not clear for in which parameters to paste the expression
    I have the impression, i´m just millimeters away to the solution whith this,
    further help would be greatly appreciated
    thanks
    ann
  • Dan Ebberts
    December 19, 2010 at 12:25 am
    It looks like part of this line got chopped off:
    for( i=0; i < n; i++) {
    Dan
  • Anne Meo
    December 19, 2010 at 12:59 am
    Thanks Dan,
    got a little ahead, but getting this error message:
    AFX-Warning: Expression result must be of dimension 1, not 2
    Expression disabled
    Any help? In which parameter should activate the expression?
    Thanks so much
    Ann
