Activity Forums Adobe After Effects Expressions Script for comparing layer height for positioning.
  • Script for comparing layer height for positioning.
    Posted by Billy Sides on August 6, 2013 at 8:11 pm
    I am working on a template that needs to compare the first three layers. I’m checking to see which layer is the tallest. Here is what I have for the expression.
    VH1 = thisComp.layer(1).height;
    VH2 = thisComp.layer(2).height;
    VH3 = thisComp.layer(3).height;
    VH1S = VH1*([thisComp.layer(1).transform.scale[0]]/100);
    VH2S = VH2*([thisComp.layer(2).transform.scale[0]]/100);
    VH3S = VH3*([thisComp.layer(3).transform.scale[0]]/100);
    if ( VH1S >= VH2S && VH3S )
    H = VH1S
    else if ( VH2S >= VH1S && VH3S )
    H = VH2S
    else if ( VH3S >= VH1S && VH2S )
    H = VH3S
    50 + H - VH3S
    The problem is that in this case the third if statement for some reason is never true.
    I tried changing the code like so:
    H = VH1S
    H = VH2S
    H = VH3S
    50 + H - VH3S
    But then the second if statement is never true…am I missing something?
    Any help is appreciated.
    -bsides
    Billy Sides replied 13 years ago 2 Members · 2 Replies
  • Dan Ebberts
    August 6, 2013 at 8:59 pm
    Your condition tests need to be more like this:
    if((VH1S >= VH2S) && (VH1S >= VH3S))
    and your last conditional should just be an else (instead of an else if)
    Dan
  • Billy Sides
    August 6, 2013 at 9:32 pm
    Perfect! I think I knew that at some point…but I forget little things like that when I haven’t used it in awhile.
    Thanks again Dan you’re the best!
    -bsides
