Activity Forums Compression Techniques script error
  • script error
    Posted by Peter Robertson on July 3, 2013 at 3:19 pm
    I was able to make a script a few months ago with the generous help of this forum but now it has stopped working. When I try to run:
    #!/bin/sh
    for (( i=0; i<97; i+=30 ))
    do ffmpeg -ss $i -t 10 -acodec copy -vcodec copy -i movie.mp4 index_$i.mov
    done
    I get the error:
    ./IndexVidBash.sh: line 1: {rtf1ansiansicpg1252cocoartf1187cocoasubrtf390: command not found
    ./IndexVidBash.sh: line 2: syntax error near unexpected token `}’
    ./IndexVidBash.sh: line 2: `\cocoascreenfonts1{\fonttbl\f0\fmodern\fcharset0 Courier;\f1\fnil\fcharset0 LucidaGrande;}’
    Any suggestion on how to fix this?
    Peter
    Pedro
    Lou Logan replied 13 years, 2 months ago 2 Members · 2 Replies
  • Peter Robertson
    July 3, 2013 at 3:56 pm
    My bad. The error appears to have been caused by the fact that I was using Text Edit to edit my .sh file–not a good idea. Saving the script with a different editor fixed the problem.
    FYI–the syntax for ffmpeg has changed since I used this script. With newer versions of ffmpeg you will need to use
    do ffmpeg -ss $i -t 10 -i YUWinter.mp4 -acodec copy -vcodec copy index_$i.mov
    the ‘-acodec copy -vcodec copy’ needs to be placed AFTER the output file.
    Peter
    Pedro
  • Lou Logan
    July 5, 2013 at 8:57 pm
    [Peter Robertson] “the ‘-acodec copy -vcodec copy’ needs to be placed AFTER the output file.”
    Don’t you mean “after the *input* file”? Please use the CODE button on your commands and console outputs.
