Activity Forums Adobe Illustrator Script – eps to png – delete objects outside artboard AND crop to artwork
  • Script – eps to png – delete objects outside artboard AND crop to artwork
    Posted by Giacomo Bompan on September 17, 2012 at 8:53 pm
    hello everyone,
    I need to convert thousands (!) of .eps’s to .png’s and I have found a script that does the work well.
    ( it’s this one: https://forums.adobe.com/message/4052650 )
    Problem is that all my .eps have a tag outside the artboard and when i run the following command:
    pngExportOpts.artBoardClipping = true;
    it cuts out the tag but it obviously keeps the whole artboard space with the file, while I want it to be cropped right around the artwork.
    Question is:
    Is there a simple command that sums to the previous one (inside the same script!) telling AI to crop to artwork after it got rid of all the stuff placed outside the artboard?
    I hope I could explain myself.
    Thank you very much in advance for reading 🙂
    P.B.
    Giacomo Bompan replied 13 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
