Activity › Forums › Adobe After Effects Expressions › SCRIPT: Determine the number of values in a property
  • SCRIPT: Determine the number of values in a property
    Posted by Yoan Boisjoli on March 29, 2023 at 12:51 pm
    Hey everyone!
    I’m writing a short script where I need a function to determine how many set of values a property has (Example is opacity is selected, the alert should read 1, if it’s position it should read 2 (x and y) and so on).
    So far it seems to work with single properties (like opacity) and 3D position (x, y and z). It return respectively 1 and 3. But it also returns 3 when dealing with arrays of two like position and scale.
    Here’s the function:
    function getPropertyValuesCount() {
    var activeItem = app.project.activeItem;
    var selectedLayers = activeItem.selectedLayers;
    var selectedProperties = selectedLayers[0].selectedProperties;
    var property = selectedProperties[0];
    var valuesCount = 0;
    if (property.propertyValueType !== PropertyValueType.NO_VALUE) {
    try {
    if (property.value.length) {
    valuesCount = property.value.length;
    } else {
    valuesCount = 1;
    } catch (e) {
    alert("Error occurred while determining the number of values: " + e.message);
    return;
    } else {
    alert("The selected property has no value.");
    return;
    alert(valuesCount);
    getPropertyValuesCount();
    If you’re able to spot what I got wrong.
    Thanks in advance !
    Filip Vandueren replied 3 years, 5 months ago 3 Members · 5 Replies
  • Tomas Bumbulevičius
    March 29, 2023 at 1:05 pm
    Hey Yoan, the problem is that even though two dimensional property is set to 2D, it reads three values?
    propertyValueType actually returns a four digits number, specific for the property. If you are dealing only with transformations, you could use that number to specify counts.
  • Yoan Boisjoli
    March 29, 2023 at 1:12 pm
    Thanks for the reply Tomas!
    Yeah I don’t think I’m on the right track with propertyValueType I’m starting to think that I should maybe use value.length instead.
    I actually managed to do it in the expression editor in after effects with:
    var p = thisComp.layer("Orange Solid 1").transform.position;
    var numVal = p.value.length;
    if(!numVal){
    1;
    }else{
    p.value.length;
    When there was only one value, it returned nothing that my reasoning behind the if(!numVal).
    But can’t get it to work in the script.
  • Filip Vandueren
    March 29, 2023 at 9:55 pm
    Like Tomas said, behind the scenes position is always a 3D property, it’s just that when the layer is set to 2D, the 3rd value is 0.
    Just like normal rotation is still called Z rotation for a 2D layer, it’s probably programmed so values don’t need to be copied around into different properties when a layer changes.
    In Epressions, AE seem to do some logic so they see it as 2 vs -long arrays, but not in scripting alas.
  • Yoan Boisjoli
    March 30, 2023 at 1:08 am
    I manage to obtain the result that I wanted by checking if the layer is 2D or 3D and manually targeting scale, position and anchor point. But if I select an effect’s property, I still have to figure out how to let the script know about it. Right now I’m manually putting the index of the effect’s property.
    Here’s what I have so far:
    if (!activeItem || !(activeItem instanceof CompItem)) {
    alert("Please select a composition.");
    return;
    if (selectedLayers.length === 0) {
    alert("Please select a layer.");
    return;
    if (selectedProperties.length === 0) {
    alert("Please select a property.");
    return;
    var layer = selectedLayers[0];
    var is3DLayer = layer.threeDLayer;
    var isEffectProperty = property.propertyGroup(1).matchName.indexOf("ADBE Effect Parade");
    try {
    if (property.value && property.value.length) {
    // Check if the layer is 2D and the selected property is either Position or Scale
    if (!is3DLayer && (property.matchName === "ADBE Position" || property.matchName === "ADBE Scale" || property.matchName === "ADBE Anchor Point")) {
    valuesCount = 2;
    // Check if the property is within an effect and has two values
    if (isEffectProperty && valuesCount === 1 && typeof property.value[1] !== "undefined") {
    valuesCount = 2;
    } else {
    valuesCount = 1;
    } catch (e) {
    alert(e.message);
    return;
    } else {
    return;
    alert(valuesCount);
  • Filip Vandueren
    March 30, 2023 at 7:08 am
    Well for Effect Properties I think you can just use value.length ?
    They use Point controls or 3D Point controls and those don’t do the switching around like position parameters do based on 2D/3D status ?
