Activity Forums Adobe After Effects Expressions Script: Closing $.colorPicker(); also closes the Script UI window (dialog)
  • Script: Closing $.colorPicker(); also closes the Script UI window (dialog)
    Posted by John Gate on March 17, 2019 at 12:58 pm
    Hi there,
    I’m using $.colorPicker(); and whenever i call it i have to show an alert after that to avoid Window(“dialog”) getting closed automatically.
    What should i do?
    Please advise
    var color_decimal = $.colorPicker();
    alert("color changed"); //so it dont auto closes the dialog
    John Gate replied 7 years, 6 months ago 3 Members · 5 Replies
  • Dan Ebberts
    March 17, 2019 at 3:38 pm
    I’ve never had to do anything like that–$.colorPicker() works fine for me. How are you launching your main window?
    Dan
  • John Gate
    March 17, 2019 at 8:02 pm
    Thanks for your reply Dan,
    If you copy paste and run following code, and click button which will show color picker on After Effects (Mac).
    and when you close the picker, it will also auto close the dialog.
    testColorPicker();
    function testColorPicker(){
    var myWindow = new Window("dialog", "Test Color", undefined, {
    resizeable: true
    myWindow.add("button", undefined, "show picker").onClick = function(){
    myWindow.show();
  • Dan Ebberts
    March 17, 2019 at 9:54 pm
    When I close the color picker, the window stays open. I’m on Windows though.
    Dan
  • Lars Jandel
    March 17, 2019 at 10:03 pm
    Try this – not on my Mac atm either, but the .update() solved this issue for me in the past:
    testColorPicker();
    var myWindow = new Window("dialog", "Test Color", undefined, {resizeable: true});
    myWindow.update();
    myWindow.show();
  • John Gate
    March 18, 2019 at 7:21 am
    Thank you guys ☺
    Dan’s revised code solved the solution
    myWindow.update();
