Activity › Forums › Adobe After Effects Expressions › [SCRIPT] Choosing the folder destination when duplicating a comp
  • [SCRIPT] Choosing the folder destination when duplicating a comp
    Posted by David Delayat on August 17, 2016 at 5:05 pm
    Hi everyone !
    I’m working on a script that duplicates comps and changes the text layers in it with datas from excel sheets. Everything works fine, but I would like to make the project “readable”, because the script creates 500 comps, divided in 30 topics. So I need, when it created a comp, to store it in a previously created folder. Any idea to access it ? It would be a kind of “selection” attribute, but writable.
    Thanks a lot 🙂
    David
    David Delayat replied 10 years, 1 month ago 2 Members · 3 Replies
  • Dan Ebberts
    August 17, 2016 at 6:20 pm
    Assuming that you have a variable referencing the folder object, it would be like this:
    myComp.parentFolder = myFolder;
    Dan
  • David Delayat
    August 17, 2016 at 6:23 pm
    I found something interesting by looking in the data navigator on Extendscript !
    My compItem has an attribute named “parentFolder”, which is R/W.
    When I create folders, I’m storing them into an array, so I can access them by an index.
    I just have to set myComp.parentFolder to myFolders[i].id and the job’s done !
    Thanks all ! Sometimes writting down the question helps finding the answer 🙂
    myFolders.push(app.project.items.addFolder(folderName)) ;
    myComp.parentFolder = myFolders[0].id ;
  • David Delayat
    August 17, 2016 at 6:25 pm
    Thanks a lot Dan ! I was writing my answer at the same time. I tryed your solution without the “Folder.id” and it works well !
    Have a nice day 🙂
