Activity Forums Adobe After Effects Expressions Script adding effect too many times.
  • Script adding effect too many times.
    Posted by Kevin Snyder on November 8, 2022 at 7:03 pm
    I have a script to apply an effect to selected layers and turn off an expression on the applied effect. It works when I have the layers of interest selected. However, if I have layer transform properties (position scale, opacity, rotation) selected when I run the script, the effect is applied several times to the layer with the selected transform properties. Is there a way to only apply the effect once per layer if transform properties are selected with the layers?
    function addPos(){
    app.beginUndoGroup("TEST");
    var myComp = app.project.activeItem;
    var myLayers = myComp.selectedLayers;
    var scriptFolderPath = File($.fileName).path;
    var colorFolderPath = scriptFolderPath + encodeURI("/fp_presets");
    var ffxFile = new File(colorFolderPath + encodeURI("/FP_position.ffx"));
    myComp.applyPreset(ffxFile);
    for (var i =0; i < myLayers.length; i++){
    var myProp = myLayers[i].effect("FP - Position")("Position Offset");
    myProp.expressionEnabled = false;
    app.endUndoGroup();
    addPos();
    Kevin Snyder replied 3 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    November 8, 2022 at 7:27 pm
    I haven’t tested this at all, but I would set it up like this:
    function addPos(){
    function deselectAll(theComp);
    for (var i = 1; i <= theComp.numLayers; i++){
    theComp.layer(i).selected = false;
    deselectAll(myComp);
    myLayers[i].selected = true;
    myLayers[i].applyPreset(ffxFile);
    app.endUndoGroup();
    addPos();
  • Kevin Snyder
    November 8, 2022 at 8:09 pm
    That’s great. Thank you.
