Activity › Forums › Apple Final Cut Pro Legacy › script
script
Posted by Mark Cookman on May 3, 2006 at 7:37 amI regularly import a short .mov sequence and then take a freeze of each frame into the timeline, its quite repetitive, how should I go about automating this?
regards
MarkPeter Wiggins replied 20 years, 4 months ago 4 Members · 3 Replies -
Debe
May 3, 2006 at 1:47 pmUse Quicktime Pro to export the .mov as an Image Sequence and import those separate images into Final Cut. You can change the default length of imported stills in the User Preferences. Click on the Editing tab at the top of the window and the first box is “Freeze/Still Duration”.
Hope this helps!
debe
Wes Plate
May 3, 2006 at 3:14 pmThere isn’t an easy way. FCP can’t be scripted per se, but you COULD create an XML file that contained all your freezes. But it isn’t easy business.
Creating an image sequence as suggested in the other reply is a good idea.
— Wes Plate
Automatic Duck -
Peter Wiggins
May 4, 2006 at 10:37 amMotion does the same as QT Pro too.
If you were really clever you could set up a template which would do most of the hard work for youPeter
