Activity › Forums › Apple Motion › scribble effect
scribble effect
Posted by Alex Martinez on March 1, 2011 at 9:40 pmCan a scribble effect be created in motion 3 for text ? Thanks in advance..
Andy Neil replied 15 years, 6 months ago 4 Members · 10 Replies -
Stephen Smith
March 1, 2011 at 10:25 pmYes, you can make it from scratch…..or….you can use some of the pre-built effects. To find them go to Library, LiveFonts and then there are a few to choose from such as “clerk”, “Freehand”, “Gust”, “hand”, “Script” and “Tap”. Hope this is of help and best of luck.
Stephen Smith
Utah Video ProductionsCheck out my Motion Training DVD
Check out my Motion Tutorials
Alex Martinez
March 1, 2011 at 11:16 pmThanks for the response.. Is there any way I can change the font or color for these livefonts? Thanks again
Stephen Smith
March 1, 2011 at 11:30 pmUnfortunately you can’t change the font…but you can change the font’s color. You need to use an HSV Adjust filter to do this. Slap it on your Text object and tweak away.
Stephen Smith
Stephen Smith
March 1, 2011 at 11:36 pmOh sorry, there are lots of ways to do something. For changing the color of the font do this:
Select the text with the applied LiveFont, click the Text tab in the Inspector, then click the Style tab.
Use the Color well or color picker to define a new color.
To define a mix value between the default LiveFont color and the new color, click the disclosure triangle in the Face Color controls and adjust the Color Mix slider or value slider. A Color Mix value of 0% leaves the LiveFont at its original color; 100% completely changes the LiveFont to the new color.
Best of luck.
Stephen Smith
Alex Martinez
March 2, 2011 at 12:18 amThanks so much… I want to try and do it from scratch because I would really like to keep the font I’m using… Is there anything you can suggest… Thanks again
Stephen Smith
March 2, 2011 at 12:27 amThis is where thinks get a little more tricky. You need to use the paint, bezier or b-spline tool and trace your text. Make sure your b-spline (or whatever) shape is white. Add a Write on Behavior to it so it animates. Then add an image mask to it so the white shape becomes invisible reveals the text. Here is a link to a tutorial on using an Image mask in Motion.
I have a great chapter on this subject matter in my training DVD Moving with Motion that I think is worth checking out. Of course I’m biased. Best of luck and hope this helps.
Stephen Smith
Alex Martinez
March 2, 2011 at 5:39 amTHANKS SO MUCH… YOUR TIPS WERE VERY HELPFUL.. I’LL BE SURE TO GET YOUR DVD …THANKS AGAIN
Stephen Smith
March 2, 2011 at 3:47 pmHappy to help and best of luck.
Stephen Smith
Mark Suszko
March 2, 2011 at 10:19 pmI liked this info too, bookmarked for future use. I was reminded that the original source of LiveType was a product called India, and in it, you could create your own live fonts, even animated fonts. Some of the animated Livetype fonts may be repurposed from the original India app. If you could find a copy of India, and something to run it on, you could build your own font that way. You’d have to be some kind of obscessed individual to go that far, though, I guess.
Andy Neil
March 4, 2011 at 6:10 pmHere’s a tutorial right here on the cow that shows the exact effect you’re attempting.
Hope this helps.
Andy
https://www.timesavertutorials.com
