Activity Forums Apple Final Cut Pro Legacy screenshots webpages
  • screenshots webpages
    Posted by Jay Wolf on June 11, 2008 at 1:12 pm
    I’ve made a screenshot of a webpage using cmd-shift-4 and imported this (1200×1000) image into FCP for use in a dv-pal 16×9 project.
    Although the image looks really crisp in Preview, it looks very soft focus on my LCD ref monitor from the FCP timeline.
    Also, the webpage ‘trembles’ a lot, even after using the deinterlace filter
    How can I get this picture to look good?
    tia,
    Wolf
    G5 Quad, 3.5 Gig RAM, OS 10.4.10, FCS 2
    Jay Wolf replied 18 years, 3 months ago 4 Members · 5 Replies
  • Captain Mench
    June 11, 2008 at 1:31 pm
    There is a lot of information (pixels) you are compressing to your video which is NOT 1200×1000.
    A few things you can try.
    Make sure the render is rendered ALL the way. No dynamic preview.
    Resize the image in Photoshop to somehting smaller. Photoshop’s dithering is much better than FCP.
    Keep it 1200×1000 and 100% in the timeline and then just pan around using the Motion tab.
    Good luck,
    CaptM
  • David Roth weiss
    June 11, 2008 at 2:09 pm
    [Imagine Video] “Also, the webpage ‘trembles’ a lot, even after using the deinterlace filter”
    First, remove the deinterlace filter, unless your plan is to remove half the vertical resolution and achieve nothing else such as fixing the issue you want to fix. There is nothing interlaced about a screen capture…
    Next, add a Directional Blur set at 0-degrees and amount 1 or 2, then rerender. That should do the trick.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Jay Wolf
    June 11, 2008 at 3:21 pm
    Thanks, guys. yes, David, you are right of course about deinterlacing a screenshot- I forgot to mention I also used screencapture software iShowU to make a QT clip from the webpage and got the same lousy results.
    I resized in Photoshop but the results are still disappointing… maybe I should just go ahead and film the LCD-screen…
  • Bret Williams
    June 12, 2008 at 5:29 am
    Doing a screenshot limits the resolution. While there’s nothing you can do about bitmapped jpegs and such on the webpages, you can increase the resolution of just about everything else with no limit. CSS items, text, and more will be sharp as a tack at any size if you save the webpage as a pdf. Simply print, then choose save as pdf.
    You now have a pdf you can open in photoshop or illustrator and resize to your liking. You can zoom in on just a paragraph of text or a links bar and it’s crystal clear.
  • Jay Wolf
    June 13, 2008 at 2:09 pm
    Good tip, Bret. Thanks.
