Activity Forums Apple Final Cut Pro Legacy Screenc capture software for use with Final Cut Pro
  • Screenc capture software for use with Final Cut Pro
    Posted by Kyrsten Thompson on August 21, 2009 at 7:28 pm
    Has anyone had experience in creating a video screen capture to be edited in Final Cut? I have a client who wants to do that, but is using Adobe Captivate, which doesn’t have MAC version available. Is there any software out there that will create FCP compatible files so I can add a voice over and make a few minor edits?
    Any help is appreciated.
    Jeremy Garchow replied 17 years ago 4 Members · 4 Replies
  • Paul Figgiani
    August 21, 2009 at 8:04 pm
    Kyrsten,
    I recommend Screenium.
    https://www.synium.de/products/screenium/index.html
    Set it up to capture using the Apple Intermediate codec @ 30 fps. Then output using the same codec and settings. This will yield files running at 30 fps that can be edited in Final Cut. Make sure you configure your FCP project sequence accordingly.
    It works well.
    -paul.
  • Paul Figgiani
    August 21, 2009 at 8:15 pm
    … and let me expand on this:
    Try capturing your screen activity (if possible) at 1920×1080. Import the footage into a 720p (1280×720) sequence. This will give you a bit of head room to perform zooms on specific areas of the footage without loosing image quality.
    Output to 1280×720. You will be happy with the results.
    -paul.
  • John Fishback
    August 21, 2009 at 8:52 pm
    ScreenFlow https://www.telestream.net/screen-flow/overview.htm Excellent product.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Jeremy Garchow
    August 21, 2009 at 8:53 pm
