Activity › Forums › Adobe Premiere Pro › Screen Timeout using titler – CS4
  • Screen Timeout using titler – CS4
    Posted by Mike Cohen on August 11, 2011 at 10:14 pm
    Occasionally I can be composing or editing a simple title in CS4, and the screen goes white, program is basically frozen.
    If you click anything with the mouse you get asked if you’d like to close the program, or check online then close the program. Actually, I would not like to do either of those things!
    I need not be in the titler – sometimes this simply happens when doing other mundane editing – nothing super fancy is involved here.
    Windows 7
    i7
    GeForce GTX260
    internal eSATA storage
    editing HDV
    Mike Cohen
    Vince Becquiot replied 15 years, 1 month ago 2 Members · 1 Reply
  • Vince Becquiot
    August 12, 2011 at 3:21 am
    Hi Mike,
    Is your hard drive lit when that happens? Also worth checking your temps just in case.
    I have seen it happen once in a while in the past, although not recently after we upgraded to a better RAID array.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
