Activity Forums Avid Media Composer Screen Size
  • Screen Size
    Posted by Nick Anarky on May 6, 2011 at 2:29 pm
    Hey there,
    I’m putting together some clips for a trailer i’ve made, he problem is the frame size has to be 800x400pixels. And when i export it it comes out at the standard 4:3 set up. Can anyone help me?
    Nick
    Jeff Greenberg replied 15 years, 4 months ago 3 Members · 5 Replies
  • Bill Stephan
    May 6, 2011 at 4:36 pm
    If the Avid export refuses to make the precise specs you want, then export the footage same size and re-render it in After Effects. Being a resoultion-independent system, you can make it render any size or aspect ratio you want.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • Nick Anarky
    May 6, 2011 at 5:14 pm
    By same size do you mean at the 4:3 ratio?
    Thank you ^_^
    Nick
  • Jeff Greenberg
    May 8, 2011 at 12:26 am
    Nick,
    You’re working with what type of footage? SD? HD? SD widescreen or SD 4:3?
    Why 800×400? That’s a very strange video size. That’s 2:1 (which no camera shoots, short of a Red.)
    If you could give us a little more to go on…
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Nick Anarky
    May 8, 2011 at 3:57 pm
    I’m doing animation, and it was meant to be 800×480, we’re doing a games trailer for the iPod Touch and iPhone, so thats the resolution we have to use.
    Just need to know if there is a way to set the resolution, cause it’s not letting me do it. And I don’t have after effects.
    Cheers.
  • Jeff Greenberg
    May 8, 2011 at 8:10 pm
    Nick,
    Nope. Avid is tied broadcast video formats. The iPhone and iPod touch are optimized for widescreen versions of those formats as well.
    From this page for the iPod Touch
    TV and video
    H.264 video up to 720p, 30 frames per second, Main Profile level 3.1 with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats
    MPEG-4 video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Simple Profile with AAC-LC audio up to 160 Kbps per channel, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats
    Motion JPEG (M-JPEG) up to 35 Mbps, 1280 by 720 pixels, 30 frames per second, audio in ulaw, PCM stereo audio in .avi file format
    Support for 1024 by 768 pixels with Apple VGA Adapter; 576p and 480p with Apple Component AV Cable; 576i and 480i with Apple Composite AV Cable (cables sold separately)
    It handles standard video formats just fine (480p, 720p) and while it can store larger formats, they’re meant for display over the VGA adapter.
    I suggest you go back and talk about 720p or 480p widescreen.
    Best,
    Jeff G
