Activity Forums Adobe After Effects screen replacing mobile +aspect ratio
  • screen replacing mobile +aspect ratio
    Posted by Dawud Ali on May 22, 2013 at 6:23 pm
    Hi All
    Question about using conerpin data from mocha to after effects, for screen replacement of a different screen aspect ratio, than that of the tracked footage e.g to replace a mobile phone screen.
    I’m aware that the footage or the pre-comp corner pin data is to be pasted onto from mocha should have the same ‘screen res’ and frame rate as the tracked footage. So it’s simple to replace a tv or desktop computer but not the same for mobile screen, on which the new footage would not match and appear queezed on the width. or if you have a pre-comp with the res set to a mobile phone it will appear stretched.
    So what is the workaround to this problem please. Thanks in advance!!!!
    Dawud Ali replied 13 years, 3 months ago 3 Members · 4 Replies
  • Cassius Marques
    May 22, 2013 at 6:32 pm
    Your workflow should be like this:
    Have a proper mobile screen resolution composition inside the project resolution composition that has the corner pin data applyed.
    Then you can either stretch the mobile screen comp to fit the project comp (shortcut ctrl + alt +f).
    Or you can turn on collapse transformation on the comp with the corner pin and it should allign proper.
  • Dawud Ali
    May 22, 2013 at 6:38 pm
    Sounds very simple! will give it a try.
    Thanks CM
  • Roland R. kahlenberg
    May 25, 2013 at 3:17 am
    See this thread, https://forums.creativecow.net/thread/2/1009853#1009859
    which explains how to use mocha’s Align Surface feature.
    mocha’s Align Surface feature allows you to retain the original aspect ratio of your insert layer even after applying corner pin tracking data.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE
  • Dawud Ali
    May 29, 2013 at 11:51 am
    Thanks for all the info!!
