Activity › Forums › Adobe Premiere Pro › Screen keying + motion stops key effect?
  • Screen keying + motion stops key effect?
    Posted by Yagfxg33k on August 27, 2006 at 9:33 pm
    I have a muzzle flash that I want to composite over a shot. I have to rotate and move the muzzle flash to match the fottage. My problem is that they keying works fine (screen key – BG on muzzle flash is black) unless I move or rotate the muzzle flash clip.
    As soon as any change occurs in the default motion filter, the keying goes away. I also tried the transform filter but got the same results. I tried moving the keying filter before and after the transform filter but no dice. Anyone know what the trick is here? I am using PP 2 but it’s the same deal in 1.5.1.
    Yagfxg33k replied 20 years, 1 month ago 2 Members · 3 Replies
  • Yagfxg33k
    August 28, 2006 at 7:09 pm
    Wow – so NO ONE has any ideas here?
  • Steven L. gotz
    August 28, 2006 at 10:30 pm
    I answered your question on another forum. But just to answer it here as well in case someone doesn’t see the other one:
    I just tried it. The workaround works great. There is a bug in the Screen Key. Perhaps I didn’t explain it fully. The motion has to be in the sequence with the explosion. Try this:
    Create a new sequence named “Explosion”.
    Add the shot to track one of the new sequence.
    Add the Space Explosion clip to track two.
    Temporarily add a Luma Key to the explosion…this is only temporary.
    Add the motion to the Space Explosion clip in track two.
    Apply any necessary keyframes to control the motion.
    Once you are happy with the results, delete the Luma key, then delete the clip of the shot, and move the explosion to track one (optional)
    Now put the Explosion Sequence into the Master Sequence over the original clip of the shot. Apply the Screen key.
    That ought to do it for you since it does it for me.
    Of course, with your explosions, you might just say to heck with it and use a Luma Key instead of a Screen Key. But the workaround doesn’t take that long. You decide.
    Steven
    https://www.stevengotz.com
  • Yagfxg33k
    August 30, 2006 at 5:46 pm
    Again, thanks again, Steven. Your work around allowed me to meet my deadline. I also have your Z1 PP charts printed out and in the binder in my prod kit notebook 🙂
    You are the man!
