Activity Forums Maxon Cinema 4D Screen Going Black in Live Selection Mode
  • Screen Going Black in Live Selection Mode
    Posted by Sean Lloyd on December 8, 2022 at 12:13 am
    Hi All,
    When I am in live selection mode and left click to make a multi-selection, my screen goes black so I can’t see what I’m selecting. Any ideas?
    I have virtually the same set up on my laptop, but it doesn’t do it there. Both are Macs.
    Thanks in advance….
    Sean Lloyd replied 3 years, 9 months ago 2 Members · 2 Replies
  • Usama Aslam
    December 10, 2022 at 10:14 pm
    This is a well known problem and it occurs when the version of cinema 4d is not compatible with your desktop.
    I recommend the following:
    1. Go to your preference and try changing your display to openGl.
    2. While booting your cinema 4d hold down shift Ctrl (command) till your cinema 4d comes up.
    If the following does not work. Try installing a lower version for your desktop.
  • Sean Lloyd
    December 11, 2022 at 12:24 am
    Hi Usama,
    Thanks very much for the reply. I will check it out and post the results. Thanks, again
