Activity › Forums › Apple Final Cut Pro Legacy › scratchy, black “picture”
  • scratchy, black “picture”
    Posted by Tad Newberry on February 23, 2006 at 9:44 pm
    king of the dumb questions and weird problems…
    occaisionally my monitor shows me (barely!) a “scratchy” monochrome picture as the output from FCP. other channels on the monitor work fine, tapes play fine on the monitor from the deck, so it seems it is not the monitor itself, but maybe a nasty FCP (or Decklink) cable? i’ve trashed prefs, with no change. i’ve also tried another monitor, same “picture.”
    thanks for helping out a bonehead,
    jtn
    Tad Newberry replied 20 years, 7 months ago 2 Members · 4 Replies
  • Bryce Whiteside
    February 24, 2006 at 5:09 am
    Possibly it is loosing sync reference. Is there a common mode you are in when the monitor goes monochrome?
    Does the Decklink card playout okay to the tape deck?
    Inquiring minds…
    Bryce Whiteside
    Don’t worry Mr. B. I have a cunning plan…
    PowerBook 1.67 Ghz ATI 9700 128 MB 2 GB
    Mac OS X 10.4.5 QuickTime Pro 7.0.4
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
    After Effects 6.5
  • Tad Newberry
    February 24, 2006 at 8:21 am
    sorry for my extreme ignorance, but what do you mean by “common mode” and when you say “Does the Decklink card playout okay to the tape deck?” do you mean just recording to tape? because just playing off the timeline is what gives me the yucky pix…even though it looks “great” in the viewer and canvas windows. by the way, recording to tape gives me the same yucky pix.
    jtn
  • Bryce Whiteside
    February 24, 2006 at 8:54 pm
    By common mode means are you in Edit Tape, Log & Capture or Print to Tape when the monitor goes on the fritz. For example does the monitor fritz out when in Log & Capture only.
    The common denominator here is the Decklink card and its breakout cable since it affects your monitor and VTR.
    Is the change in the monitor instantaneously or does it seems to fade, first loosing color and then getting progressively dark? If that happens, I would suspect and reference signal issue between the Decklink card and your Monitor.
    I would first investigate if I have the latest drivers for the Decklink card. I would also note if the video going weird is related to time of day-temperature or time after firing up your Mac which would indicate a heat related intermittent component failure issue with the Decklink.
    Inquiring minds…
    Bryce Whiteside
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
    After Effects 6.5
  • Tad Newberry
    February 25, 2006 at 6:38 am
    i was just logging on to claim that i do believe it is a heat issue, when i saw your post. when i first turn on the computer today, all was fine. so heat is the only thing i can see that might cause this. thanks!
    jtn
