Activity › Forums › Panasonic Cameras › scratched lens repair
  • scratched lens repair
    Posted by Chris Gallaway on April 7, 2006 at 1:25 am
    Hello all,
    I bought a used 100 that was described as in excellent condition with no wear–it came with a scratch on the lens that noticeable mars the picture. I’m trying to decide now whether to pursue a refund or mess with getting it repaired. It looks like the glass on the front of the 100 is a sort of built-in protective filter, separate from the pricey Leica-Dicomar lens; so I’m hoping it would be relatively inexpensive to get this superficial glass replaced. But I’m unfamiliar with the construction of these camcorders and the cost of repair. Can anyone give me an idea of how complicated it is to fix this and about how much it would cost? I’d greatly appreciate the help. Thanks, Chris
    Kmac444445 replied 20 years, 5 months ago 3 Members · 2 Replies
  • Noah Kadner
    April 7, 2006 at 11:08 am
    If there is a UV filter optionally attached in front of the lens- you unscrew that and get a new one- cost $10. If the original owner did not get a UV filter and the scratch is actually on the lens itself it could be quite expensive to repair though it may be worth going to a service center first to confirm that. There’s so many used DVX100s out there nowadays and in good condition- if you have the stomach to pursue a refund it might be simpler.
    -Noah
  • Kmac444445
    April 7, 2006 at 3:28 pm
    If it’s just the protective filter (on the outside) and not the actual lens (on the inside), then simply remove the filter and purchase a new one.
    The outer filter is threaded on to the camera. (Lefty loosey.)
    B&H sells them — if I recall correctly — for about $20. In the meantime, you could shoot without the filter, just be really really careful.
    To find the lens filter, look up the camera on B&H, then go to “Accessories” and the protective filter will be listed there.
