Activity Forums Apple Final Cut Pro Legacy Scratch, Media, and Cache Disk Strategies for FCP 5.0.4…
  • Scratch, Media, and Cache Disk Strategies for FCP 5.0.4…
    Posted by Dave Mac on February 10, 2006 at 7:18 pm
    Today is my day for questions… 😉
    In preparation for adding a RAID to my hardware setup (G5 system), I would like to learn how others have their systems configured for optimal disk performance with FCP 5. I did a few searches, read the docs, and glanced at Sean Cullen’s (et al.) excellent “Optimizing Your Final Cut Pro System.”
    I know not to use the startup disk as your FCP scratch disk (that one is noted almost everywhere), unless you’re using a PowerBook. Though, I wonder, for PowerBook use, if using a FireWire (FW), or SATA, drive connected via a PC card would work pretty well (especially during captures over FW, as you wouldn’t be interfering with the primary FW bus).
    I know that several people use their second internal drive as the FCP “scratch disk” and external FW/SATA drives for media storage (among the infinite variations possible). Instead of trying to describe most possible combinations, I will state my current “best guess” and let everyone comment.
    My system will have two internal SATA drives and an external RAID. I work primarily with DV-25, uncompressed SD, and DVC Pro HD. Here’s my tentative plan:
    • System and FCP on startup disk.
    • Use the RAID for A/V capture and render (set in FCP), and general media storage (video, audio, stills, animations).
    • Use the second internal disk for waveform and thumbnail caches, as well as the autosave vault.
    How does this sound? Thanks for your assistance.
    -Dave
    David Bogie replied 20 years, 7 months ago 2 Members · 1 Reply
  • David Bogie
    February 10, 2006 at 10:43 pm
    That’s fine.
    But most people do not understand RAID types or the benefit/risk trade-offs. There’s nothing unusual about your scratch disk designations so spend your time researching your RAID setup.
    bogiesan
