Activity Forums Apple Final Cut Pro Legacy Scratch disk settings
  • Scratch disk settings
    Posted by Pduhamel on October 18, 2005 at 6:35 pm
    I would like some suggestion to optimize my hard drives. I’m running on a powerbook with an external HD. Is it better to make capture Audio-Video two separate files or the same? Is it better to make the external HD for the Capture AND the render, or simply the capture on external HD and render on internal HD? Thanks for any suggestion or new knowledge!
    Have a nice editing!
    Rayden
    Final Cut Pro 4.5 HD user
    Jerry Hofmann replied 20 years, 11 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    October 19, 2005 at 2:12 am
    You should not capture DV as separate files.
    Put all captures and Renders on that FW drive, and put everything else on the startup disk.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
