Activity › Forums › Apple Final Cut Pro Legacy › Scratch Disk
Scratch Disk
Posted by Thomas Baxter on May 15, 2005 at 4:30 amHey…
I need to remove video files from my scratch disk…how do i do that?….Thanks!
-Thomas
Jerry Hofmann replied 21 years, 3 months ago 3 Members · 2 Replies -
Fx Bear
May 15, 2005 at 5:04 amYou can use Media Manager inside of FCP. You can also use the drag the files to the trash method and choose “Empty The Trash” option from the file menu in Finder. I generally like using the last method as I can better see what I need or want to delete.
Jerry Hofmann
May 15, 2005 at 1:13 pmSelect everything you want to delete in the Browser.
Control click on one item and select “Make Offline”. Follow the prompts.
Then to delete render files, open the Render Manager from the Tools menu. And delete all renders from the dialog box which will open. This is the only way to really sort what’s getting deleted render file wise.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
