Activity Forums Blackmagic Design Scopes in PPRO 2 don’t work with BM projects
  • Scopes in PPRO 2 don’t work with BM projects
    Posted by Sean Cusson on February 6, 2006 at 5:54 pm
    Has anyone else run into this problem? I use the Decklink Extreme, driver version 5.1.1 (which I believe is the most recent) on Windows XP. When I create/use a Black Magic project in Premiere Pro 2, the built in scopes will not work. This isn’t a case of not ganging to the source monitor, they simply won’t work. If I create a non-BM project, the scopes work just fine. Any ideas?
    Sean Cusson
    Q media design
    sean@qmediadesign.ca
    Sean Cusson replied 20 years, 7 months ago 3 Members · 4 Replies
  • Mike Johnton
    February 6, 2006 at 6:03 pm
    Premiere Pro 2.0 is only supported under their 5.4 driver…
  • Sean Cusson
    February 6, 2006 at 7:28 pm
    Actually when you look at the driver under device manager it first shows up as 5.1.1 untill you get deeper into Driver Details at which point it states File Version: 5,4,0,5 So I did have the latest drivers running. I uninstalled and re-installed with no luck. The scopes still don’t work.
    Sean Cusson
    Q media design
  • Adrian Tecson
    February 7, 2006 at 6:29 am
    same here, scopes dont work too.
  • Sean Cusson
    February 7, 2006 at 5:52 pm
    Damn. I was hoping it was just something I had messed up.
    Sean Cusson
    Q media design
