Activity › Forums › DaVinci Resolve › Scopebox 3.0
Robert Houllahan
March 8, 2012 at 7:58 pmTHat is great it seems like a Mini with a thunderbolt I/O like Ultrastudio would be a great little machine for scopes and portable to set.
I upgraded our V2.0 on a Dual G5 2Ghz at work and it definitely takes a hit in responsiveness compared to V2.0 it seems like there is less CPU load (around 70%) but maybe that GPU is not so hot? The G5 has a ATI Radeon 9600 128Mb card some other card recommended?
Will be buying a few more Scopebox licenses…
-Rob-
Robert Houllahan
Director / Colorist
Cinelab Inc.
http://www.cinelab.comMAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma.
Teo Rižnar
March 8, 2012 at 9:58 pmI am just thinking of an idea. About looping the HDSDI cables out of the DI system, first they go to scopes, than they go to LUB box, than displays… OK if you have a display with built in option of importing a calibration LUT than it is irrelevant, but would sometime in future Scopebox be able to process also LUTs? So you could measure the image without LUT, just pure signal, than apply the LUT only on output that goes out of the video card (ideally separate LUT for each signal, #1 and #2 HDSDI). Than you could get rid of LUT box and get one loop HDSDI less? Whoul it make the difference? Specially in the price LUT box (even HDlink) comparing to Scopebox?
Color grade reel: https://vimeo.com/15480583
Cofounder of https://nuframe.si postproductionSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Mike Woodworth
March 8, 2012 at 10:04 pmThat’s strange… we’re finding perf to be better under v3.0. Can you send us an email – support@divergentmedia.com so we can try to track down what might be happening?
-mike
Prathvish Hegde
March 10, 2012 at 2:02 pmhi ,
just mike would love to see it on windows also as we have resolve on windows also.
trying it out on mac…………..prathvish hegde
colorist
